I need some help on what to do if I want to upgrade my 77 spider with a Weber 38 ADLD 150 . Unfortunately my car has the accelerator linkage with the ''drum and spring'' type.
What do I need to change if I want to install a 38 ADLD?
Thanks for the input
Upgrading a 77, with a Weber 38ADLD 150
- Your car is a: 1975 Spider
Re: Upgrading a 77, with a Weber 38ADLD 150
you need the cable, valve cover and linkage mounted to the valve cover and the rod from the twist linkage to the carb. it is a very simple change
son has 78 spider
son has 78 spider
Thanks, Beek
What cable type should I get?
Also sorry for my ignorance what do you mean by "rod from the twist linkage to the carb"?
Thanks again
Thanks again
Here is what I´m trying to do:
http://www.mirafiori.com/faq/content/we ... 38_adl.htm
I found a 38ADLD150 in Italy and my car is in France, so shipping should not be so bad.
Just and update.
I install the 38ADL (primary 175 secondary 200) on my 77 and what a change!!!!!! this thing is nuts it has lot more power than my previous 34ADF.
The only thing is that at idle the engine runs a little ruff. Any idea on the ruff idle at around 1000RPM?
I have to inform you that I have adjustable cam gears with 40/80 cams, high compression pistons a 4/1 manifold with 2.25 exhaust system, and Mark's distributor less system set at 12 degree advance.
Thanks for any input.
Coise
Coise
- Your car is a: 131 supermirafiori
Hi!
Why don't you put on 2x44 IDF with with those cams and exhaust,it would boost power!
Cheers
Alf
Cheers
Alf
- toplessexpat
- Your car is a: 1976 Spider 1800
Isn't that a function of the cam as opposed to the Carb? My 38ADL idles smoothly.coise wrote:The only thing is that at idle the engine runs a little ruff. Any idea on the ruff idle at around 1000RPM?
A
Thanks for the inputs.
2x44IDF is not an option for me, I use my car in the summer only and I don't want to spend my time tuning it every year.
As for the cams I will try to tweak the timing a little to see what happens. Maybe not enough overlap...what do you think?
This carb is great specially when the secondary barrel opens up it feels like a turbo
Salut
Salut
You don't say what your idle jet size is, or if you tried adjusting the idle mixture?
Primary is 200 secondary is 171, and yes I tried turning the idle mixture screw. Also the carb is brand new unused old stock.
- toplessexpat
Precisely the reason why I keep mine and refuse to move to dual 44's like a friend of mine hascoise wrote:This carb is great specially when the secondary barrel opens up it feels like a turbo
Jetting (like Csaba says) is also a potential. I seemed to have to back out the mixture screw further than I'd anticipated when I set mine up - however - it runs just great, isn't overly rich, and is fun.
Perhaps the timing could be tweaked, do you have adjustable cam gears?
Finally some sport cams just have a lumpy idle... what does the manufacturer of yours say?
A
Hm, those sound like main jet sizes, idle jets sizes are usually in the 50-60 range, or thereabouts.coise wrote:Primary is 200 secondary is 171, and yes I tried turning the idle mixture screw. Also the carb is brand new unused old stock.
- toplessexpat
Aren't those jets the wrong way round?
Primary 170, Secondary 200??
