cam covers part duex
Tappy
Your car is a: 124 spider 2000 1979
Re: cam covers part duex
Post by Tappy »
if you seeking a cheap solution , i used flexible home appliance wire , there are 3 wires in a cable , brown , blue , yellow/green
i used the 1.5 mm wires they stand up to 16 A/220V so there would not be a problem ...
FineItalianAutomobile TechnologyImage
manoa matt
Post by manoa matt »
Mike,
I'm currently running Accel 8mm copper core (yellow) wires. They work great, and are reported to provide the most energy to the plug. I can't remember the specific item number right now, the box is at home, but I bought them at a local performance parts store for around $37. Sounds like alot for a set of wires, but they are for a V8 motor and given the short runs from the Fiat dizzy to the plugs you can get two wire sets out of one box. They are also non-assembled so you can create custom routing to elimenate extra bunches of wires in the engine compartment. I'll post the item number when I get home.
Matt
TulsaSpider
Post by TulsaSpider »
Where could I find an air cleaner like that!!
mbouse
Post by mbouse »
thanks, Matt!
Are you referring to my "lunch box" air breather?
http://www.webercarbsdirect.com
http://www.piercemanifolds.com
timspider
Post by timspider »
I know this is an old thread, but does anyone know where I can find a lunchbox air cleaner for a 77 spider? I can't seem to pull up anything using those keywords. I didn't see anything at the weber site. Thanks
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
The web sites listed in the post above both have them.
R/
fiasco
Post by fiasco »
timspider wrote:I know this is an old thread, but does anyone know where I can find a lunchbox air cleaner for a 77 spider? I can't seem to pull up anything using those keywords. I didn't see anything at the weber site. Thanks
Mark Allison also sells one on his site. Follow the link and scroll down just a bit.
http://allisonsautomotive.com/products.html#engine
-- se
Steve Eubanks
tartan18
Post by tartan18 »
I went with red wires that came with the Computronix ignition system that Mark sells. The lunch box air filter is also from Mark when I upgraded to his EMPI 32/36 DFEV. Also got a Griot's Garage Italian air horn for Christmas last year. Mounted the air horn between the fender well and radiator (also from Mark) on the driver's side. But after adding up all I've spent at Allison Automotive I still don't have a T-shirt. :cry: Oh snap ... just ordered the Big Brake Kit from Mark and did I mention the Monza wheels,95 amp alternator, new wood dash and assorted other goodies ?
Jim MacKenzie
1975 Fiat Spider
