Cover plate
fiat218
Cover plate
Post by fiat218 »
What do you guys do with the mechanical fuel pump ,when you convert it to a electric fuel pump?
Is there a cover replacement or do you get one made
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Re: Cover plate
Post by dmwhiteoak »
I believe there is a cover plate. I just let one go with an engine I sold. Mine on my car has the same plate.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
fiat218
Re: Cover plate
Post by fiat218 »
Ok thanks, I can make one I guess
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
manoa matt
Re: Cover plate
Post by manoa matt »
I think there is a Ford or Chevy block off plate that works also.
131
Re: Cover plate
Post by 131 »
This bloke had 1 left as of 5 April.
http://www.131mirafiori.com/smf/index.php?topic=5543.0
Mick.
81SPIDERMATT
Re: Cover plate
Post by 81SPIDERMATT »
iap shows one in their weber conversion kits..... maybe a phone call and some sweet talking
fiat218
Re: Cover plate
Post by fiat218 »
Great. Thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
manoa matt
Re: Cover plate
Just make one out of aluminum or steel plate. Use a gasket or the phenolic spacer as a template.
Alternatively you could use a nylon/derlin cutting board. (usually white, but I've seen green and red) Its about the right thickness, machines easily, and will withstand the heat. You will need to sand down one side to remove the knurled surface so it will seal.
fiat218
Re: Cover plate
Post by fiat218 »
I am.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
