What do you guys do with the mechanical fuel pump ,when you convert it to a electric fuel pump?
Is there a cover replacement or do you get one made
Cover plate
Cover plate
Re: Cover plate
I believe there is a cover plate. I just let one go with an engine I sold. Mine on my car has the same plate.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
Re: Cover plate
Ok thanks, I can make one I guess
- manoa matt
Re: Cover plate
I think there is a Ford or Chevy block off plate that works also.
Re: Cover plate
Mick.
- 81SPIDERMATT
Re: Cover plate
iap shows one in their weber conversion kits..... maybe a phone call and some sweet talking
Re: Cover plate
Great. Thanks
- manoa matt
Re: Cover plate
Just make one out of aluminum or steel plate. Use a gasket or the phenolic spacer as a template.
Alternatively you could use a nylon/derlin cutting board. (usually white, but I've seen green and red) Its about the right thickness, machines easily, and will withstand the heat. You will need to sand down one side to remove the knurled surface so it will seal.
Re: Cover plate
I am.
