It is about 99% done , few little thing still have to be done.
One of them - carb linkage
P.S. Forum cuts some pictures .
Just right click it and click View Image
I have noticed in the later 2L the area where the mechanical fuel pump went is blanked off, neither here nor there really....Special wrote:Thank you guys !
Yes it is 2L block with 1.8L head.
FI or not - I don't know how to tell them apart.
Well - unfortunately it is a budget buildSo Cal Mark wrote:still running points with a perf engine? That ignition doesn't have much output, especially at high rpms
So if the block does not have hole for the pump it is FI block ?divace73 wrote:I have noticed in the later 2L the area where the mechanical fuel pump went is blanked off, neither here nor there really....Special wrote:Thank you guys !
It is , I made it myself.giuliot60 wrote:Looks really nice. I've never seen that top center cover. Is it custom?
Just what I had noticed on the Argenta (late 132) block I have in my car that came out with FI, sort of makes sense, no need for the machining for a mechanical fuel pump if it has an external fuel pump??Special wrote:So if the block does not have hole for the pump it is FI block ?divace73 wrote:I have noticed in the later 2L the area where the mechanical fuel pump went is blanked off, neither here nor there really....Special wrote:Thank you guys !
