Special TC Engine
Special
Your car is a: 1974 Special TC
Special TC Engine
Post by Special »
Here is my new Special TC engine.
It is about 99% done , few little thing still have to be done.
One of them - carb linkage :?:
P.S. Forum cuts some pictures .
Just right click it and click View Image
Daniel
Re: Special TC Engine
Post by Daniel »
Looks good nice and shiny i like the center plate gives the engine a modern feel.
divace73
Post by divace73 »
I like what you have done with the top of it, Is that a 2L FI block?
Are you able to get your hands on the linkage off the original twin IDF set up?
Cheers David
see my >>You tube channel<<
focodave
Post by focodave »
Sweet!
If it runs as good as it looks, you've got something special there.
1970 MGB GT (my other hobby)
Special
Post by Special »
Thank you guys !
Yes it is 2L block with 1.8L head.
FI or not - I don't know how to tell them apart.
I have not figured out the linkage yet , if I'd have the original one - I'd use it , but I asked few people and nobody has a spare complete mechanism .
I ordered some levers from ebay and as soon as they arrive I'll try to make them work.
I'll keep you posted.
That looks really nice!
Danno
Post by Danno »
I don't see any TC... Maybe i do not know what TC means?
Edit: Lol, I'm an idiot. On my other forums TC means Turbo Charged. Here it means Twin Cam. Got it.
still running points with a perf engine? That ignition doesn't have much output, especially at high rpms
divace73
Post by divace73 »
Special wrote:Thank you guys !
I have noticed in the later 2L the area where the mechanical fuel pump went is blanked off, neither here nor there really....
Cheers David
Special
Post by Special »
So Cal Mark wrote:still running points with a perf engine? That ignition doesn't have much output, especially at high rpms
Well - unfortunately it is a budget build :|
Special
Post by Special »
So if the block does not have hole for the pump it is FI block ?
giuliot60
Your car is a: 81 Fiat Turbo removed Spider
Post by giuliot60 »
Looks really nice. I've never seen that top center cover. Is it custom?
Giulio/Charlotte
Special
Post by Special »
giuliot60 wrote:Looks really nice. I've never seen that top center cover. Is it custom?
It is , I made it myself.
divace73
Post by divace73 »
Just what I had noticed on the Argenta (late 132) block I have in my car that came out with FI, sort of makes sense, no need for the machining for a mechanical fuel pump if it has an external fuel pump??
Cheers David
rodman
Post by rodman »
what kinda Horse Power are you expecting to get out this motor???
