removing adhesive from painted surface
ga.spyder
Post by ga.spyder »
I have some pinstripes on the car ,and one side was peeling.Decided to remove and replace.When I took off the drivers side they pretty much fell off,leaving little residue.I like the look of the car w/o the pinstripes so I decided to remove the other side.They came off....1 inch at a time!!Left behind a lot of residue.Anyone have a suggestion how to get the residue off without damaging the paint? Alcohol(Crown Royal) :D ?,peanut butter?,80 grit sandpaper :cry: ? The car has had a repaint long ago,no idea what type paint,etc..
Craig
Craig Nelson
Fling It Around Turns !
mdrburchette
Re: removing adhesive from painted surface
Post by mdrburchette »
3M makes an adhesive remover. You may want to try an inconspicuous place with acetone or paint thinner to see of the finish can be waxed back to life.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
ronarthur
Your car is a: 1977 Fiat Spider
Post by ronarthur »
You might want to try "goo-be-gone". (spelling??) It usually works pretty well.
ga.spyder
Post by ga.spyder »
I used isopropyl alcohol on a soft cloth and got it off.It was slow going but it is all gone.I immediately waxed those areas,feeling that I probably removed the existing wax. I will clay bar the whole car and rewax before spring.I really think the body lines show up better w/o the pinstripes,I wish I had removed them before now.
I was afraid to use the 3m or the ''goof off'' products for fear of ruining paint.I would have just put back the pinstripes if the residue didnt come off.And I didnt use up my Crown Royal or my peanut butter! :lol:
Craig
Craig Nelson
manoa matt
Post by manoa matt »
Goof-off and acetone are strong stuff and would probably take the paint off. Alcohol was a good choice, "Gunk" makes a bug and tar remover that is good and won't hurt the paint. Woodford Reserve might work and tastes great too.
perthling
Post by perthling »
Eucalyptus oil is very good for that purpose too - but I don't know how common it is 'up over' (compared with 'down under').
_______________________
Perthling
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
http://www.fiatlancia.org.au
