Rewiring Kits
pope
Re: Rewiring Kits
Post by pope »
Brad is going to be offline till next year,
I dont have the link for it.
baltobernie
Re: Rewiring Kits
Post by baltobernie »
PM me your e-mail; I'll send it directly to you.
whalford
Re: Rewiring Kits
Post by whalford »
Got it today - Thanks Robert!
Re: Rewiring Kits
I would like to know what others think about this. Unless the existing wire harness has visible evidance of burning up I would stick with it. Trouble-shooting the original wire issues should be easier than rewiring the car. IF one of the harness sections does look real bad, why not replace it with a good used one??
racydave
Re: Rewiring Kits
Post by racydave »
It probably depends what you have to work with. I repaired mine, but, thats my job. Bernie posted alot of good info on wire repairs and proper tools. In any case, its usefull to run another feed wire to un-load the factory feed wires, and relay the headlight-wiper circut. Also the ignition circut was hooked to new circut. 10 gauge wire should be more than adaquet, fused at the battery. Ever try to type with a cat on your lap? Bobb Katt wants to play...
bradartigue
Re: Rewiring Kits
Post by bradartigue »
The site is being changed up I can email you the doc if you still need it.
whalford wrote:Argh! I haven't logged on in quite a while and the article isn't currently available on Brads site. Any chance someone has a copy they can email or PM?
wandersome
Re: Rewiring Kits
Post by wandersome »
Hi, I have a 79/80 cali FI car that hadn't been ran for 16 years and we were struggling to get the fuel pump running. this was traced back to a blown in-line fuse that was situated near the steering column that doesn't appear on any wiring diagram i have found. both the fuse holder and fuse had corroded with age so chopping in a new fuse holder appears to have solved the problem.
Mick.
