I soaked and scrubbed the original windshield gasket. It is in good shape with good flexibility. I started a practice run at installing the new windshield. I have the gasket seated over the "V" groove bottom support (this took a bit of manipulation; I don't think I could seat it properly with the windshield in the gasket). It appears that with 2 of us working, we can next fully install the windshield in the gasket. Then, slip the frame onto the gasket and tighten the 4 bolts to the frame.
Am I going at this in the proper order?
The body shop also gave me some putty (I think he called it "Dum Dum" ) to lay in this "V" channel. I think its purpose is to put pressure on the gasket to press against the windshield's bottom edge. Has anyone else used this stuff? Is it a good idea?
Warren
Windshield Install Procedure???
Re: Windshield Install Procedure???
Well, I couldnt get it installed the way I was going.
There isn't enough clearance in the door jamb to get the windshield frame in. Another start over. These are the steps I took to get it installed. Definately a 2 person job
Drop the steering wheel.The gage cluster needs to be removed. Then take the dash board out. The dash is held by 4 fasteners. One nut is accessed once the gage cluster is removed and the other through the hole in the top of the glove box. 2 small bolts are at the lower outer corners of the dash. This gives you access to the rear edge of the "V" channel which supports the windshield. Then:
A) Fit the gasket to the windshield;
B) Fit the windshield frame to the gasket/windshield;
C) Mount the frame loosely with the 4 bolts;
D) Have your helper push forward on the top of the frame. From inside the car, work the base of the gasket over the rear edge of the "V" channel. I used a long small slotted screwdriver that I put a slight bend in the end. With the gasket seated, tighten the frame bolts to hold in place;
E) Install the 2 chrome trim pieces in their slot in the front, bottom face of the gasket;
F) Final position the frame and torque the bolts.
When installing the dash, you will need to work the gasket flange back over the edge of the dash.
I did lay in a length of that caulking in the "V" channel. One more thing I am going to do is buy some black silicone and apply it between the rubber gasket and windshield to ensure a leak proof installation.
This job is kind of a PITA
Pulling the dash, fussing the gasket to seat, and the need for a helper make it so.
- bradartigue
I usually get drunk before working on windshields or starters. It helps.
1970 124 Spider
http://www.artigue.com/fiat
- Patron 2019
I must have been lucky, as two of us installed the assembled windshield and frame as one piece, without removing the dash on my 81....or maybe it was because the martini I had first? Brad you could be right!
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
I have found that it always helps to be fortified when attempting projects like that. Just kind of takes the edge off.
Gene
North Carolina
Gene
North Carolina
Gene
North Carolina
North Carolina
