Windshield Install Procedure???
wizard124
Post by wizard124 »
I soaked and scrubbed the original windshield gasket. It is in good shape with good flexibility. I started a practice run at installing the new windshield. I have the gasket seated over the "V" groove bottom support (this took a bit of manipulation; I don't think I could seat it properly with the windshield in the gasket). It appears that with 2 of us working, we can next fully install the windshield in the gasket. Then, slip the frame onto the gasket and tighten the 4 bolts to the frame.
Am I going at this in the proper order?
The body shop also gave me some putty (I think he called it "Dum Dum" ) to lay in this "V" channel. I think its purpose is to put pressure on the gasket to press against the windshield's bottom edge. Has anyone else used this stuff? Is it a good idea?
Warren
wizard124
Re: Windshield Install Procedure???
Post by wizard124 »
Well, I couldnt get it installed the way I was going. :(
There isn't enough clearance in the door jamb to get the windshield frame in. Another start over. These are the steps I took to get it installed. Definately a 2 person job :!:
Drop the steering wheel.The gage cluster needs to be removed. Then take the dash board out. The dash is held by 4 fasteners. One nut is accessed once the gage cluster is removed and the other through the hole in the top of the glove box. 2 small bolts are at the lower outer corners of the dash. This gives you access to the rear edge of the "V" channel which supports the windshield. Then:
A) Fit the gasket to the windshield;
B) Fit the windshield frame to the gasket/windshield;
C) Mount the frame loosely with the 4 bolts;
D) Have your helper push forward on the top of the frame. From inside the car, work the base of the gasket over the rear edge of the "V" channel. I used a long small slotted screwdriver that I put a slight bend in the end. With the gasket seated, tighten the frame bolts to hold in place;
E) Install the 2 chrome trim pieces in their slot in the front, bottom face of the gasket;
F) Final position the frame and torque the bolts.
When installing the dash, you will need to work the gasket flange back over the edge of the dash.
I did lay in a length of that caulking in the "V" channel. One more thing I am going to do is buy some black silicone and apply it between the rubber gasket and windshield to ensure a leak proof installation.
This job is kind of a PITA :shock: Pulling the dash, fussing the gasket to seat, and the need for a helper make it so.
bradartigue
Post by bradartigue »
I usually get drunk before working on windshields or starters. It helps.
76was124
Patron 2019
Patron 2019
Post by 76was124 »
I must have been lucky, as two of us installed the assembled windshield and frame as one piece, without removing the dash on my 81....or maybe it was because the martini I had first? Brad you could be right!
Current 81 Spider 2000
Previous 76 Spider
brackie1
Your car is a: 1978 124 spider
Post by brackie1 »
I have found that it always helps to be fortified when attempting projects like that. Just kind of takes the edge off. :)
Gene
North Carolina
Gene
North Carolina
SoFlaFiat
Post by SoFlaFiat »
Chianti!!! :lol:
