Has anyone adapted these for use?
http://www.vw-wagenwerks.com/servlet/th ... sh-/Detail
They look very similar the the Fiat glue-on ones, but obviously can't pop off. I am probably going to try the Dorman universal latches, but thought these might be better.
Regards,
Brian
Using early Volkswagen vent window latches?
- hayesbd
- Your car is a: 1973 Spider
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
Re: Using early Volkswagen vent windo latches?
They would likely work, the question is whether the VW glass and pillar are the same thickness as Fiat's.
Re: Using early Volkswagen vent window latches?
Let us know how you go as I suspect there would be a few interested in the result...
I tried them and they don't line up correctly
- hayesbd
Thanks, Mark! You saved me some grief for sure.
I'll just use the Dorman ones. The whistling (of course only on the driver's side!) is driving me nuts and gluing has not been too successful for me.
Brian
Brian
Can you list the Dorman part number, and does the glass need to be drilled ??
Many thanks
Baz
Many thanks
Baz
- hayesbd
Here is the Dorman universal window latch, part number 76994:
http://rbinc.com/p-22666-76994.aspx
It does not require any drilling - it just clips on, from all I can gather. It's not going to look as good as orignal latches, but right now, with the cold weather requiring top up, window up driving, it will solve the annoying whistle.
I ordered a pair from my local Advance Auto for $9.99. They will be in on Monday, so if I get a chance, I'll post a picture of what they look like installed.
Brian
Brian
FWIW, tempered glass cannot be drilled, it will shatter. Many have tried...
