Using early Volkswagen vent window latches?
hayesbd
Your car is a: 1973 Spider
Post by hayesbd »
Has anyone adapted these for use?
http://www.vw-wagenwerks.com/servlet/th ... sh-/Detail
They look very similar the the Fiat glue-on ones, but obviously can't pop off. I am probably going to try the Dorman universal latches, but thought these might be better.
Regards,
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
vandor
Re: Using early Volkswagen vent windo latches?
Post by vandor »
They would likely work, the question is whether the VW glass and pillar are the same thickness as Fiat's.
Baz
Your car is a: 1977 Fiat Spider
Re: Using early Volkswagen vent window latches?
Post by Baz »
Let us know how you go as I suspect there would be a few interested in the result...
I tried them and they don't line up correctly
hayesbd
Post by hayesbd »
Thanks, Mark! You saved me some grief for sure.
I'll just use the Dorman ones. The whistling (of course only on the driver's side!) is driving me nuts and gluing has not been too successful for me.
Brian
Baz
Post by Baz »
Can you list the Dorman part number, and does the glass need to be drilled ??
Many thanks
Baz
hayesbd
Post by hayesbd »
Here is the Dorman universal window latch, part number 76994:
http://rbinc.com/p-22666-76994.aspx
It does not require any drilling - it just clips on, from all I can gather. It's not going to look as good as orignal latches, but right now, with the cold weather requiring top up, window up driving, it will solve the annoying whistle.
I ordered a pair from my local Advance Auto for $9.99. They will be in on Monday, so if I get a chance, I'll post a picture of what they look like installed.
Brian
vandor
Post by vandor »
FWIW, tempered glass cannot be drilled, it will shatter. Many have tried...
