The end of the line!
AllyCat555
Post by AllyCat555 »
I was looking around under the dash for the door chime wire the other day and came across 3 unconnected connectors.2 were white and one was black. I hope to find out where these go, personally I had no luck searching for their connecting ends but hopefully someone on this site knows! Hopefully they have something to do with the door chime, if not it still will be an improvement to have these wires in working order:) thanks~Ally
manoa matt
Re: The end of the line!
Post by manoa matt »
The black one is a relay socket, the other two are electrical connector blocks. Take down the relay panel as seen in the first picture at the top. The two bolts/screws in the recessed areas will allow it to drop. You may find the other end of the connectors up there. The smaller one could be the door chime, and the larger one could be the wiper intermittent relay, but those are just guesses at this point.
A wiring diagram and looking at the colored wires will tell you what the connectors and relay are for. Let us know what you find.
htchevyii
Post by htchevyii »
Trey
