Indicators flashing too fast
garryness
Your car is a: 1980 Pininfarina 2000
Post by garryness »
My turn signals / indicators are flashing very quickly. I have checked all the exterior bulbs and they are all working. What I have noticed is the green turn light in the dash board is not working. Could this be the cause? ie does the circuit see it as having a light out causing it to flash quicker???
piperstan10
Your car is a: spider 1973
Re: Indicators flashing too fast
Post by piperstan10 »
Incorrect bulbs cam cause the problem, also, the flasher relay is under the dash attached to the frame, easy to replace. Check ground at flasher and at fixtures.
Stan
I purchased a flasher from AutoZone for my 81 Spider. Although they assured me it was the correct flasher. The dash indicator would not light with it installed. I ended up buying one from a Fiat Vendor and all is well now.
