Indicators flashing too fast
- Your car is a: 1980 Pininfarina 2000
My turn signals / indicators are flashing very quickly. I have checked all the exterior bulbs and they are all working. What I have noticed is the green turn light in the dash board is not working. Could this be the cause? ie does the circuit see it as having a light out causing it to flash quicker???
- Your car is a: spider 1973
Re: Indicators flashing too fast
Incorrect bulbs cam cause the problem, also, the flasher relay is under the dash attached to the frame, easy to replace. Check ground at flasher and at fixtures.
Stan
Stan
I purchased a flasher from AutoZone for my 81 Spider. Although they assured me it was the correct flasher. The dash indicator would not light with it installed. I ended up buying one from a Fiat Vendor and all is well now.
