oil pump modification
stpher
Your car is a: 1982 F I spider
Post by stpher »
Hi.
I remember seeing something about modifying oil pumps but cant find anything. Can someone help me with what modifications can be done 2 L and 1800 engines
Thanks, Rick
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Re: oil pump modification
Post by MrJD »
Im curious why you want to modify it?
narfire
Post by narfire »
My stock pump makes the 20/50 oil 60+ psi at start and higher rpms and 20-30 psi at idle when warm. Been that way for 8 years.
What is the pump not doing that you want it to do?
Chris
vandor
Post by vandor »
The mod that racers will do is to put a THIN washer under the relief valve spring, thus increasing spring pressure which increase the oil pressure at which the spring opens. Not sure if it's really needed.
stpher
Post by stpher »
I read somewhere about modifying the oil pump drive up near the splines, tapering the the sharp edge just under the splines because it was prone to breakage. Am I off base here? The rest of the pump is OK and according to Guy Croft, I can add a 2mm steel washer under the spring. That's all
Would like to see a picture on the drive done if in fact that is what is done
Thanks, Rick
