Can I stack carb spacers?
bbuckl
Post by bbuckl »
I am in the middle of an engine refresh and I am swapping out the dual plane intake for a single plane. I have one 12mm spacer for the carb, but I was thinking 2 would give me more room to work and maybe a little more low end grunt.
Can I stack them or am I setting myself up for leaks?
Brian
79 Spider 2000
Re: Can I stack carb spacers?
stack them up and put gaskets in between each one
bbuckl
Post by bbuckl »
Thanks Mark!
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Post by MrJD »
1979? What carb and intake are you using? Any potential for hood clearence issues?
danaspider
Your car is a: 1979 Spider 2000 79 vw bus
Post by danaspider »
If you have the single plane intake you can easily go .5 inch or more. Easy way to check how close you are to the hood is to loosely crumple some aluminum foil, place on top of air cleaner, close then open hood, see how much it is depressed.
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
