I am in the middle of an engine refresh and I am swapping out the dual plane intake for a single plane. I have one 12mm spacer for the carb, but I was thinking 2 would give me more room to work and maybe a little more low end grunt.
Can I stack them or am I setting myself up for leaks?
Brian
79 Spider 2000
Can I stack carb spacers?
Re: Can I stack carb spacers?
Thanks Mark!
- MrJD
1979? What carb and intake are you using? Any potential for hood clearence issues?
- danaspider
- Your car is a: 1979 Spider 2000 79 vw bus
If you have the single plane intake you can easily go .5 inch or more. Easy way to check how close you are to the hood is to loosely crumple some aluminum foil, place on top of air cleaner, close then open hood, see how much it is depressed.
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
79 Spider 2000
carb
