Trunk popper, Now with RFID remote
Today I got sidetracked from my ongoing body work and did a dry run on my trunk popper.
I am trying to keep a minimalist thing going and decided to hide the trunk release. I have also ordered an RFID transmitter which I will try. This should allow me to wave the fob near the trunk and have it release instead of a switching the car.
Here's a very short vid!
http://youtu.be/dMEIbNS6I6g
Re: Trunk popper
Just be sure you have a cable backup!
Re: Trunk popper
Thanks for the thumbs up!!
It's very simple to do and entertains the kids to boot!
Re: Trunk popper
That is great!
Re: Trunk popper, Now with RFID remote
So, yea, I'm a geek...
I added a fob remote to my trunk popper. I should be able to use the same fob to enable/disable my starter circuit which will leave me with no keys at all.
Here's another quick video,
http://youtu.be/DPYbZDQWpdM
LOL. Funny guy!
Ha,
Daniel, I'm still rubbing two sticks together compared to your tech savy
If you want any assistance with my ideal let me know i get the parts wholesale as well the solenoids are between
5 to 10 bucks relays 1 dollar each alarms depends on the brand. I wouldnt mind picking this stuff up and sending it
to you.
to you.
Brain picking and parts at wholesale.....hmmmm
Pm sent
Pm sent
If it's a tech question maybe we should post them here so the info can be assessable for the forum as well, oftenSoFlaFiat wrote:Brain picking and parts at wholesale.....hmmmm
Pm sent
times people will add some input or ideals which can be beneficial for FS.com members if they choose to do the
same mods.
Absolutely! As you probably noticed, my goal would be no keys, one remote which enables my ignition circuit and pops my trunk. Ultimately I would like an ignition start/stop button which uses an RFID proximity fob so that it is disabled when I walk away from the car. The same fob (remote) would talk to my trunk release solenoid (with a button is fine instead of the way I have just done it). I am installing a new wiring harness. I have seen many alarms and remote start systems but have not found one that will accomplish what I want without spending $500. These systems all come with remote door locks and sirens etc. I have no need for that as I never lock the car anyway. I think a brake or clutch pedal safety switch would be a great idea too. The RFID system I am using on my trunk solenoid was very cheap and obviously works fine for that, but I have decided that it would not work with the ignition since it requires the fob to be within 2" of the antenna. I would like to be able to keep the fob in my pocket.
Also, I have seen many start buttons available but can not find one that can also be wired as a kill switch, at least sold separately. Do you have a lead on such a switch and since, as I said, I'm am not too tech savy, one that comes with a decent wiring diagram?
Thanks Daniel!!
Thanks Daniel!!
