Second Gear - where to get transmission parts
HFK
Post by HFK »
Hello everyone, I need your help
Last trip out in the fall, I found that I was having random trouble shifting from 1st up into 2nd. Sometimes a little grinding like I forgot to engage the clutch, sometimes I could just feel a little tickling in the shift handle like I was actually feeling the gears engage. I put her away and hoped it was my imagination :-)
Jump to spring - I got her out and took her in for spring tune-up last week and the same issue is there. Mechanic says it is internal, and to baby her for as long as possible because this could be expensive :-(
Synchromesh?, 2nd gear? where can I get parts without having to buy a whole new transmission. I can't afford a whole new transmission (sigh). Mechanic is searching, but I want to get on the road sooner than later. I lost 3rd gear years ago and drove for quite a while without it, second is not so easy to avoid (for me at least)
1981 Spider 2000 5 speed manual. Thanks in advance for your help!
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Re: Second Gear - where to get transmission parts
Post by dmwhiteoak »
Several vendors have transmission parts. This is my favorite. autoricambi.us/products.html.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
HFK
Post by HFK »
Perfect - thank you!!
I passed the info on - I REALLY want to be on the road with the Fiat this long weekend. Wish me luck :D
sptcoupe
Your car is a: 1972 124 Sport Coupe
Post by sptcoupe »
A common issue with these trannys. Usually replacing the synchros will cure it- for a while. I find that if I pull the gear shift hard to the left when shifting into second, the "flick", or minor grinding , goes away. AR is a good source for these parts.
MTMike
Post by MTMike »
sptcoupe wrote:A common issue with these trannys. Usually replacing the synchros will cure it- for a while. I find that if I pull the gear shift hard to the left when shifting into second, the "flick", or minor grinding , goes away. AR is a good source for these parts.
My '78 has the exact same problem. All other gears are smooth, but going into 2nd always gets a bit of grind. I'll try the left pull- sounds easier than the ham-fisted rev-matching I've been doing...
HFK
Post by HFK »
I will also give it a try. We're cruising this weekend.
