i am thinking about taking the 2.0 dual idf engine out of my 79 and swap it out on my 80 2000 auto
how would that work out,GOOD 'BAD
the engine in the 80 is not that good,it has low compression, where the engine in the 79 is better, so swapping the 80 engine would be good i think ,then maybe i can just sell the 79 to some one without the engine only. everything else would stay on the car
swap engines
swap engines
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: swap engines
Should be a very simple swap.
Re: swap engines
if you plan to use the idf's with the auto, connecting the throttle linkage to the trans detent cable will be a bit of a challenge
Re: swap engines
Didnt catch the auto trans thing, duh.
Re: swap engines
well we will see what happens yet, i am debating on what to do with the 79 all together
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1975 Spider
Re: swap engines
actually, i have the linkage solution for auto trans as well, if you are using center pull on the carbs. meaning the linkage is using the ball mount between the carbs, as on the originals, there is a easy linkage to use the twist linkage from the 76 on spiders/131's
son has 78 spider
son has 78 spider
Re: swap engines
it is centerBEEK wrote:actually, i have the linkage solution for auto trans as well, if you are using center pull on the carbs. meaning the linkage is using the ball mount between the carbs, as on the originals, there is a easy linkage to use the twist linkage from the 76 on spiders/131's
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
