There, I said it.
I'm not opposed to swapping parts around every 2 years to get it through smog, but I'd sure like to open this motor up a big so that freeway merges are a little less "exciting".
Air pump, EGR, low compression, small carb, tons of vacuum stuff, etc.
Does this engine even have enough cam and compression to warrant a larger carb?
I find that advancing the timing from 0 BTDC to 10 BTDC makes a noticeable difference and it's cheap/easy to put back when it's time.
Sonny
