kick it up a notch
- 124JOE
kick it up a notch
hello all ive been gathering the parts for FI
i have a 32/32 ADFA carb with a headder
will i get more bang out of FI or a 32/36 carb?
also should i get new cams?
my car just isnt powerfull it tops out about 105mph
not that i want to go faster than that
but i want more low end power
tell me what you know
- 124ADDHE
- Your car is a: 1974 Spider Amalgamation with C40 Solex
Re: kick it up a noch
Whats your compression? I like the sounds of the carbs more but you would need one of the single-plane intakes to make a carb worthwhile, performance wise they are probably pretty close but an electronic ignition will help get the best of both if you dont already have. Your original carb sucks; I had a 34dms but sold it last year, it was quite a good carb.
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
- 124JOE
i dont know the comp
i do have a single plane manifold
and a fireball 3000 ELE ING
I have the FI 2L. I found the real wake up in my engine was the instalation of cams(Marks 274 FI cams) and adjustable cam wheels to get them dialed in correctly. I have had stock engine and head, oversized pistons & stock head, oversize pistons and massaged 1800 head(stock cams),Now oversized pistons and massaged 2LFI head with 274 cams... the best set-up yet. I also have headers and 2"exhaust, but some will argue the stock 4-2-1 manifold works well. Stock injectors and ignition.124JOE wrote:also should i get new cams?
I have not driven a car with the 32/36 but many love the upgrade over their stock carb.
Chris
- 124JOE
well im going to try the 32/36
i just bought from matt
there will be updates so stay tuned
spring is almost here
ive got a few part to install
ill take some pics for us
- 124JOE
heres a pic of carbs
on the left is a 32/36
in the mid is a 32/32
on the right is a 28/32
i have more pics of these
- 124JOE
next stop http://www.millersmule.com
- 124JOE
Re: kick it up a notch
i got it
i bent my control arm to 9 1/8 inches ball to ball
- 124JOE
well what a great day
i got my spacer today and in an hour she was good to go. i bolted down the new carb pluged a few lines, hooked up the fuel line assembled the air filter put in the battery, got 2 gallons of premium and turned it over but i had the tank empty
all winter,so no fuel in the lines ot start. anyway cranked it till it died charged it untill it died again. waited 3 min without a charge, turned it over and it stoped.so one last charge and zoom she ran! it was at 3000 so i unhooked the linkage and
re bent my throttle control bar so it was relaxed and then it was at 1500
and down the road i went,i have a video im trying to post
you can hear the exhaust because i drive it like i stole it
- 124JOE
- 124JOE
or youtube
http://youtu.be/3aJZFHpPgoo
Joe are you running a stock engine? What about exhaust? Sounds good.
- 124JOE
1800 motor header,stock center section,ansa muff
yes yes she does
thank you
yes yes she does
thank you
Sounds good Joe, was there alot of improvement with the new carb?
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- 124JOE
its a nice bit of improvement
the muff sounds better
the take off is ok but could allways be better
