If you had a choice
seabeelt
Patron 2019
Patron 2019
Re: If you had a choice
Post by seabeelt »
So possibly two issues, motor mount height to top of stock air cleaner (for flat hood), and oil pan clearance around/over cross member. I plan on install new mounts, the old ones are oil soaked and saging.
spiderrey
Post by spiderrey »
i have done this twice. Installed a 2 liter into a 70 and a 71. Didnt change the cross member. The dizzy might be an issue. Move it to the block. Turning it might help the clearance issue at the top.
vandor
Post by vandor »
Weelan wrote:Wouldn't he need the 1800's head for building the 2000?
Not if he uses high-compression pistons.
spiderrey
Post by spiderrey »
Dosent an 1800 head flow better?
vandor
Post by vandor »
seabeelt wrote:Are there any obstacles with installing the 1800 or 2000 in order to maintain the flat hood? Definitely want to keep that look.
With the 2000 you will have to rotate the distributor so it points forward, so it does not foul the hood.
The hood's center reinforcement may hit the timing belt cover, on my car I notched the center of the TB cover for a bit of extra clearance.
I had put 2 liters into early cars with an stock and also a 2000 crossmember, and I do not think it makes a difference. On my current car I slotted the engine mount to engine block holes to lower the engine a few more mm.
Fi8spider
Post by Fi8spider »
2Ltr under a flat bonnet, clearance sounds a lot like a problem I've heard of before with installing the larger lump in Fiat AC Coupes.
The engine mount from a Volvo 240 diesel RHS can be used, it's shorter and a touch harder.
240 1979–1987 Engine Mount Diesel Driver
Part No. 1229805
Scroll a down the page a little and you'll see it.
The locating lugs need to be ground off and can be shimmed up a little if needed.
http://www.swedishautoparts.com/240/Vol ... ounts.html
Cross member and engine mount to engine brackets remain the same with this mod.
The distributor can be an issue but as mentioned by vandor, turn the dizzy housing to face the fingers forward or you can go dizzy into block type if you have one handy.
131lover
Your car is a: 131 supermirafiori
Post by 131lover »
Hi!
If you need more adjustment clearence you can use Volvo 140 engine mounts, they are even lower than the one to the 240 and you can shimm them upp to the hight you want so the oil sump goes free of the crossmember and gives more space under the hood!
They are 40mm high, 65mm wide, almost the same weight as the TC engine, the 240 is 48 or 50mm high and 75mm wide!
I was born i the wrong country,Volvo country Sweden instead of Fiat country Italy!
Regards
Alf Andersson
Sweden
Fi8spider
Post by Fi8spider »
131lover wrote: They are 40mm high, 65mm wide, almost the same weight as the TC engine, the 240 is 48 or 50mm high and 75mm wide!
Great info there Alf!
Like most engine mounts they will sag over time and i'd imagine the 240 mounts would settle down by 8 or 10mm.
The measurements you've provided are a good reference point for one to start measuring from standard and make the choice, 40mm or 50mm.
htchevyii
Post by htchevyii »
I believe there is a taller Volvo engine mount that works with the x member and that you need to reindex the dist for hood clearance.
Trey
Weelan
Post by Weelan »
Oh sorry, I was thinking for his 3rd option which was the 2000 with the 1800 head.
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
So if I go with the 2L , no timing belt cover and use Mark's electronic ignition (instead of twisting the dizzy) and maybe some shorter engine mounts and/or slotting the bracket on the motor, I should have enough clearance?
Thoughts
vandor
Post by vandor »
seabeelt wrote:So if I go with the 2L , no timing belt cover and use Mark's electronic ignition (instead of twisting the dizzy) and maybe some shorter engine mounts and/or slotting the bracket on the motor, I should have enough clearance?
Thoughts
I would use the cover, just notch it. A stone under the timing belt can ruin your day.
Yes, it will fit, it has been done many times before.
Zippy
Your car is a: 1978 Fiat
Post by Zippy »
Sounds like you're close to making a decision. Let us know when you're done and we'll all come over and take her for a spin. 8)
1978 Spider
