It's ALIVE!!!
I fired 'er up this evening for the first time since I gutted it in February
It cranked twice, and fired right up. I ain't gonna lie.... it sounded wicked!
Of course, it's firing through the header, no muffler or pipe. But that cam has a serious lope to it! teeheehee.
I ran it for about 20 minutes, looking for leaks (none) weird sounds (none) and smoke (none I didn't expect) and then shut 'er down before the cops showed-up....
I need to button a few things up, re-install the dash (I pulled it back out to fix a minor issue) install a seat and then I'll run it up to the exhaust shop to have the system built.
Then I'll need to spend some time tuning those big 44's to this altitude.
And I think I'll pull the cam-cover on the intake side and degree that cam again. I'd like to be double-sure it's where I want it.
I decided this evening that I need to get Mark's distributorless ignition setup. But until I can rationalize the $$ in my budget, I'll use this vacuum advance electronic one.
Can anyone suggest a great way to pull vacuum from these webers for the advance unit? Should it be from under the throttle plate? or above it?
