it's time to start a write-up on this. Hopefully others will find it useful. Let me say first that Daniel and I have been working through all of this new stuff together and I'm very confident we'll come to a great conclusion. It's not always easy when neither of us do this for a living, and we live several states away from each other. But as far as Daniel's knowledge of this motor and what he has proposed, I trust him and respect his research and conclusions. I also trust him ethically, and so far have been very happy with the value I've gotten for my dollar.
So, I took note several months ago when Daniel posted about a new (to me) idea on cams.
See the thread here:
http://www.fiatspider.com/f08/viewtopic ... 11&t=17073
Daniel and I PM'd back-n-forth a bit, and long story short, I've got a set of these custom cams. Through the back-n-forth on it, I also ended-up with a set of custom springs and retainers... but that's a longer story.
I'm starting this thread because i think the info will be useful to others trying something new, and hopefully it'll prove-out to be a great combination and Daniel will be able to promote it to others.
Some of you may recall that this project began when I decided to desmog the car. next thing I know, I've got the car torn-down to it's withers and I've spent too much money and WAAAAY too much time.
This project didn't start-out with a plan. it's been "project-creep" since day-one.
So here's what I've got:
I lightened the rods and matched them to new 4.5mm-dome pistons in stock bore-size. I honed the cylinders really well for these new pistons / rings. I had the entire assembly balanced and included a lightened flywheel from Millers' Mule.
Once I got the cams and hi-performance springs, I started to assemble, only to discover that the springs had a slight "beehive" to them, tapering at the top just enough that I was uncomfortable with the way the retainers sat in them. I also noticed at the time that the springs seemed far too compressed in their static-state, like they would be prone to coil-bind.
I talked to Daniel, who asked me to send them back to him. After his review, he sent me back the same springs, but with a set of machined-down retainers that fit nicely in the spring.
In the meantime, I discovered that I had a couple of bent valves. I had originally planned to just button the old head back onto the motor, as I was trying to resist further creep and delays. But once I realized I had bent valves, I ordered replacements from Autoricambi. Again, I was hoping to avoid machine-work. the valves arrived, but they accidentally sent me the performance-valves. they immediately sent me the correct ones. Daniel and I had discussed big-valves previously, and he suggested that the big-valves were a waste at this stage. But when I took the head in to the machinist to do a valve-job, he pointed-out that the stock-replacement valves are 2-pc valves, welded at the taper. This is a machinist I've used and trusted for 30 years: when he says he wouldn't put 'em in a motor past 7Krpm, I trust him. So we decided to put the performance valves in. He did a beautiful job of grinding new seats and blending the SSR in the bowl.
So today I went to assemble, again. Finally. Even took a day off work to get it done.
foiled-again.
so: I get the new springs & retainers installed. ok.
I get the cams into the camboxes: ok.
I install the camboxes on the head and the new adjustable pulleys from Millers' mule.
but here's where the problems start: the cams won't turn. COIL BIND. I was correct in my initial gut that they would be binding. For anyone reading this who is unfamiliar with the term: the spring is compressed as far as it goes, the coils are stacked right on top of each other, and the valve is still not open all the way. Coil Bind.
An additional problem: because these cams are a regrind from a factory cam, they have a reduced base-circle. So on the exhaust-side, the tappets / shims have a gap around .2mm; nothing I can't work with. But on the intake-side, it is SIGNIFICANTLY greater, at about 2.5mm or more!!!
SO:
I pulled the camboxes back off. under the springs are two pieces of hardware: a thin shim (bottom) and a centering-base (top).
I removed the centering-base. I don't know why this should be needed with a single-spring (compared to the double-spring from the factory), so maybe Daniel intended this to be removed. (it is sometimes difficult to get ahold of Daniel, as he's very busy with his day job. So frequently I find I'm working through stuff he could probably save me from, if we could speak more readily).
So I removed these on the intake-side and reassembled the springs onto the head / valves.
here it is installed with the base:
and here without the base:
The cams turn, the springs don't bind. I would love to have some information on the springs about what their installed height should be, so I could reassure myself that they won't be suspect to float.... I don't know if Daniel has information on this or not, as it hasn't been a question I've raised obviously.
So then I put the cambox back on. I discovered that the shim under the spring is almost exactly 1mm in thickness, and is the correct diameter to install into the bucket on the top of the tappet, under the valve-shim. installed this way, and with a 4.2mm shim installed, I've still got a clearance of .5mm. Yes, I can get shims big enough to make that work. But I look at the amount of weight I'm adding to the valve-train, and the concern I have over the shim popping-out of the bucket, and I must say I'm nervous.
How many of y'all have used regrind cams? IS this common shim / clearance-spacing? how do YOU fix it? I've debated having the cambox milled 1mm. is that a good idea? I'll be degreeing cams anyway, so what other problems do I face if I do that? (other than yet MORE project creep, and MORE delays).
appreciate any comments. even if they are "this is what happens when you don't have a plan when you start a project" sort of comments.
again, I'm hoping that as this comes together and Daniel and I work-out some of the details, it'll become easier for someone else to follow after.
