FUEL LEAKING
fiat218
FUEL LEAKING
Post by fiat218 »
i got the new carb and it leaking under where the arrow is pointing
i can put my fingers under that part and it wet as heck
no it not the fuel line and yes it needs to be replaced,
what causing the leakage / 4 screws are tight
thanks
ronarthur
Your car is a: 1977 Fiat Spider
Re: FUEL LEAKING
Post by ronarthur »
A small tear in the gasket or a small piece of dirt maybe? Also, maybe the mating surface isn't exactly flat.
fiat218
Re: FUEL LEAKING
Post by fiat218 »
there was a rip in the gasket, it was done at the assembly,where where that was, i just put in on the car this spring,
so now i have to get a kit for it
Texasbull
Re: FUEL LEAKING
Post by Texasbull »
While you're at it, you might want to go ahead and replace those old fuel lines. A very cheap "not stranded on the side of the road" insurance policy... :lol:
fiat218
Re: FUEL LEAKING
Post by fiat218 »
lol yes that is already done :)
Kent124
Re: FUEL LEAKING
Post by Kent124 »
Weber Direct sells kits. You could also make your own gasket if you have the appropriate material laying around.
