Plugging the Choke Coolant Nipple
- opus10583
- Your car is a: 1978 CS1
Hi,
Having secured a workspace for an upcoming weekend I'm preparing to swap my 78's ADHA for a DFEV.
I have all at hand and in place save one thing: Plugging the cylinder head choke coolant tube nipple (I have one of Mark's SS heater pipes without the choke tap).
Joe was helpful to suggest a workable solution, plug a section of hose with silicone, but my previous experiences with the stuff around the house leave me with little confidence in the material as a long term solution.
How have others solved this problem?
Mark
Mark
ANDIAMMO: 2012 500 ABARTH
- 124JOE
Re: Plugging the Choke Coolant Nipple
black RTV silicone gasket maker
wont peel off like cheap silicone
i fill one end of a hose then trim when dry
put it on the nipple and secure with clamp
If it were me, I'd use a short piece of hose with a bolt/hose clamp on the end of it. Tightening a clamp around a bolt gives me a little more confidence than relying on a plug of RTV which I'm sure has worked fine for Joe.
- tartan18
I used a small rubber cap and then secured it with a small hose clamp.
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
- opus10583
Hi,tartan18 wrote:I used a small rubber cap and then secured it with a small hose clamp.
Where'd you source that: Auto parts, plumbing supply?
Mark
- 124JOE
hobby shop stores have rubber caps
- opus10583
Hi Joe,124JOE wrote:hobby shop stores have rubber caps
Thanks, and thanks again for the silicone tip, I really don't have much luck with the stuff though.
"A man's got to know his limitations".
Where in a hobby shop am I looking for high-heat high pressure rubber caps?
Mark
- opus10583
I think we have a winner.digitech wrote:If it were me, I'd use a short piece of hose with a bolt/hose clamp on the end of it. Tightening a clamp around a bolt gives me a little more confidence than relying on a plug of RTV which I'm sure has worked fine for Joe.
Mark
- manoa matt
If the intake manifold is removed from the car you can simply unscrew the fitting and find the appropriate threaded plug. I haven't found a rubber cap that I'd be comfortable with, they are usually only for vacumn or emissions. The bolt in the hose is by default the best solution.
- tartan18
I got my plug from the local Autozone store. But I like Matt's solution better -- unscrew the fitting and replace with a screw in plug. That is what I am going to do.
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
- opus10583
Thanks!tartan18 wrote:I got my plug from the local Autozone store. But I like Matt's solution better -- unscrew the fitting and replace with a screw in plug. That is what I am going to do.
- opus10583
Hi Matt,manoa matt wrote:If the intake manifold is removed from the car you can simply unscrew the fitting and find the appropriate threaded plug. I haven't found a rubber cap that I'd be comfortable with, they are usually only for vacumn or emissions. The bolt in the hose is by default the best solution.
I haven't been under the hood in a while, why 'intake out of the car'? Isn't the tap on the head?
Thanks.
Mark
- manoa matt
That fitting is screwed into the intake manifold. The reason to have the manifold removed is that the fitting is in a hard to reach area and you might not have proper acces to remove it. Otherwise just use the hose and bolt solution.
- opus10583
Thanks Matt.manoa matt wrote:That fitting is screwed into the intake manifold. The reason to have the manifold removed is that the fitting is in a hard to reach area and you might not have proper acces to remove it. Otherwise just use the hose and bolt solution.
