Plugging the Choke Coolant Nipple
opus10583
Your car is a: 1978 CS1
Post by opus10583 »
Hi,
Having secured a workspace for an upcoming weekend I'm preparing to swap my 78's ADHA for a DFEV.
I have all at hand and in place save one thing: Plugging the cylinder head choke coolant tube nipple (I have one of Mark's SS heater pipes without the choke tap).
Joe was helpful to suggest a workable solution, plug a section of hose with silicone, but my previous experiences with the stuff around the house leave me with little confidence in the material as a long term solution.
How have others solved this problem?
Mark
ANDIAMMO: 2012 500 ABARTH
124JOE
Re: Plugging the Choke Coolant Nipple
Post by 124JOE »
black RTV silicone gasket maker
wont peel off like cheap silicone
i fill one end of a hose then trim when dry
put it on the nipple and secure with clamp
digitech
Post by digitech »
If it were me, I'd use a short piece of hose with a bolt/hose clamp on the end of it. Tightening a clamp around a bolt gives me a little more confidence than relying on a plug of RTV which I'm sure has worked fine for Joe.
tartan18
Post by tartan18 »
I used a small rubber cap and then secured it with a small hose clamp.
Jim MacKenzie
1975 Fiat Spider
opus10583
Post by opus10583 »
tartan18 wrote:I used a small rubber cap and then secured it with a small hose clamp.
Hi,
Where'd you source that: Auto parts, plumbing supply?
Mark
124JOE
Post by 124JOE »
hobby shop stores have rubber caps
opus10583
Post by opus10583 »
124JOE wrote:hobby shop stores have rubber caps
Hi Joe,
Thanks, and thanks again for the silicone tip, I really don't have much luck with the stuff though.
"A man's got to know his limitations".
Where in a hobby shop am I looking for high-heat high pressure rubber caps?
Mark
opus10583
Post by opus10583 »
digitech wrote:If it were me, I'd use a short piece of hose with a bolt/hose clamp on the end of it. Tightening a clamp around a bolt gives me a little more confidence than relying on a plug of RTV which I'm sure has worked fine for Joe.
I think we have a winner.
Mark
manoa matt
Post by manoa matt »
If the intake manifold is removed from the car you can simply unscrew the fitting and find the appropriate threaded plug. I haven't found a rubber cap that I'd be comfortable with, they are usually only for vacumn or emissions. The bolt in the hose is by default the best solution.
tartan18
Post by tartan18 »
I got my plug from the local Autozone store. But I like Matt's solution better -- unscrew the fitting and replace with a screw in plug. That is what I am going to do.
Jim MacKenzie
1975 Fiat Spider
opus10583
Post by opus10583 »
tartan18 wrote:I got my plug from the local Autozone store. But I like Matt's solution better -- unscrew the fitting and replace with a screw in plug. That is what I am going to do.
Thanks!
opus10583
Post by opus10583 »
manoa matt wrote:If the intake manifold is removed from the car you can simply unscrew the fitting and find the appropriate threaded plug. I haven't found a rubber cap that I'd be comfortable with, they are usually only for vacumn or emissions. The bolt in the hose is by default the best solution.
Hi Matt,
I haven't been under the hood in a while, why 'intake out of the car'? Isn't the tap on the head?
Thanks.
Mark
manoa matt
That fitting is screwed into the intake manifold. The reason to have the manifold removed is that the fitting is in a hard to reach area and you might not have proper acces to remove it. Otherwise just use the hose and bolt solution.
opus10583
Post by opus10583 »
manoa matt wrote:That fitting is screwed into the intake manifold. The reason to have the manifold removed is that the fitting is in a hard to reach area and you might not have proper acces to remove it. Otherwise just use the hose and bolt solution.
Thanks Matt.
