1800 head
Re: 1800 head
Hey Beek, that is one shiney head. Wonder though I have heard two points of view..polished or "swirled" ports. I don't want to open another can of worms here, but what are your ideas on that? I have a massaged 1800 head with big valves on the shelf and wonder if I should have the ports touched up a bit. They are matched to gasket and a set of headers, but are smooth inside.
Chris
Chris
- 124JOE
Re: 1800 head
if your head is matched and smooth
then it has been ported and polished
i wouldnt mess with it any more
also has big valves it should snort and fly
- Your car is a: 1975 Spider
Re: 1800 head
Porting heads is a learned skill, you can kill the performance of an engine easily with improper port configurations, making certain areas larger and such, can actually hurt the performance. Gasket matching is one place where wrong doing can really hurt a motor. Some people make the mistake of creating an expansion area, where the head opens up in the port then necks down after the match, on the intake the port should be slightly larger than the manifold, and the exhaust the opposite. Exact port matching can be done but is very meticulous.narfire wrote:Hey Beek, that is one shiney head. Wonder though I have heard two points of view..polished or "swirled" ports. I don't want to open another can of worms here, but what are your ideas on that? I have a massaged 1800 head with big valves on the shelf and wonder if I should have the ports touched up a bit. They are matched to gasket and a set of headers, but are smooth inside.
Chris
son has 78 spider
son has 78 spider
Re: 1800 head
Thanks Beek. I did'nt do the work of course but had a fellow that has built a fair number of engines and bike engines (drag bikes and drag snowmobiles) I'll have a look later and see if these virgin eyes can spot any difference.
- opus10583
- Your car is a: 1978 CS1
Re: 1800 head
Hi,
Will the 1608 head fit and function on the 1800 block?
Mark
Mark
ANDIAMMO: 2012 500 ABARTH
Re: 1800 head
the front water jacket is the issue with fitment, it will directly bolt up, but the front water passage will have to be welded up to a smaller size, use the 1800 head gasket for a guide. it can be done, is it worth it? depends on how much welding and resurfacing costs
son has 78 spider
son has 78 spider
- opus10583
Re: 1800 head
Thanks "BEEK",BEEK wrote:the front water jacket is the issue with fitment, it will directly bolt up, but the front water passage will have to be welded up to a smaller size, use the 1800 head gasket for a guide. it can be done, is it worth it? depends on how much welding and resurfacing costs
What's my best option then, on an 1800 block, a Lancia casting?
Mark
Re: 1800 head
if you can find one a 1592 head, same as an 1800 but no emissions, i belive the combustion chamber may be a few cc's smaller, but i dont remember. im sure someone here will chime in with that knowledge.
son has 78 spider
son has 78 spider
- opus10583
Re: 1800 head
Smaller chambers would be exactly what I'm after, any idea how to research that?BEEK wrote:if you can find one a 1592 head, same as an 1800 but no emissions, i belive the combustion chamber may be a few cc's smaller, but i dont remember. im sure someone here will chime in with that knowledge.
Mark
Re: 1800 head
Im comverting to FI this winter and will use this 1600TC head, that means I will have a 1800TC (european) head without emissons left over when its done.
You can also use a Fiat Ritmo 130TC head and port the intake a little bit so there will be a more straight angle to the valves, that will make it similar to the 1600TC head.
Re: 1800 head
unfortunatly the 130tc head is not available here in the usa, it is a much better casting as i have been told, but i have never had my hands on one. i would love to have one though. price one for me including shipping
son has 78 spider
son has 78 spider
Re: 1800 head
The 130TC head is hard to get even over here but I have a friend that might be able to get one for you if you wantBEEK wrote:unfortunatly the 130tc head is not available here in the usa, it is a much better casting as i have been told, but i have never had my hands on one. i would love to have one though. price one for me including shipping
Re: 1800 head
The Regata 100S head is basically the same as the 130TC, they go for $150-$200 in OZ.BEEK wrote:unfortunatly the 130tc head is not available here in the usa, it is a much better casting as i have been told, but i have never had my hands on one. i would love to have one though. price one for me including shipping
Mick.
- engineerted
Re: 1800 head
Swede,
The head in your second photo is not a 1600 head, it is an 1800 head. The 1600 head has symmetrical bowles, not offset in 1&4 as shown. Sorry dude.
Ted
Ted
Ted
Re: 1800 head
Depends on the 1600. The Regata 100S is a 1600 twincam with 84 mm bores, probably the same motor Swede is talking about.engineerted wrote:Swede,
Ted
Mick.
