Started off with a 1975 spider that was pretty trashed except for a very straight body and minimal rust. It was painted and driven for a while untouched until it kept overheating and leaking oil from every possible gasket. At this point I parked it and pulled the engine and began the rebuild of the car.
engine/drive-train-
bored out .4mm
balanced crank, con rods, pistons, pulley and flywheel
vicks high comp 4 mm dome pistons
IAP billet performance cams
IAP 4-2-1 header
machined head and new guides and cleaned valves
polished crank
new clutch
dual Weber DCNF 42~~~ hopefully will be changed to dual idf's
suspension-
Plated crossmember
new control arm bushings
new sway bar bushings
new balljoints
cut springs~~~ hopefully to be changed out for lowering springs
At this point I have some finishing touches on the engine before I put it back in, and dealing with the wiring which is a mess on this car. I cant find a good wiring diagram for the 1975 which has some slight differences compared to the good and clear 1974 and 76 wiring diagrams that I found off of artigue.com.
anyways thats all and pictures of the whole car will be up soon but here is one off my phone
