190 hp from down under!
Here is a dyno video of a 2L Fiat TC using my 410fi stage 2 cams and distributorless ignition
190hp and 158 ft lbs of torque
http://www.youtube.com/watch?v=jZn2Nljt9mk
narfire
Re: 190 hp from down under!
Post by narfire »
Impressive. What other mods were done to the engine do you know of? I have your FI cams as well but I don't believe I'm anywhere near 150+ HP but there is a marked(no pun intended) increase in performance.
Chris
I've asked the owner for the engine specs, but I know he's using dcoe carbs since the car is rhd. I'll post as soon as he sends me the details
sptcoupe
Your car is a: 1972 124 Sport Coupe
Post by sptcoupe »
Mark - any updates? Those are really great results!
custom pistons from JE with 12:1 cr, Chevrolet H beam con rods from Scat. 44mm intake valves, 38mm exhaust valves, extensive head porting and my 410fi camshafts along with my distributorless ignition system
sptcoupe
Post by sptcoupe »
Nice set up, and with those DCOEs I am not at all surpised with those results!
