Swaybar Problem
Mark_vaughn
Swaybar Problem
Post by Mark_vaughn »
I had a issue come up when re-installing the front swaybar. Broke the bolt.
Anyone had a similar situation? Any thoughts on how to fix it? I have thought about tapping it for a bolt, but I don't know if there is enough metal there. I don't know how to get behind it to replace the existing bolt either.
Help!
mbouse
Post by mbouse »
try using an easy out to remove the bolt.
can be a PITA
Mark_vaughn
Is it a stud? Or will it back out upward like a bolt? It is soaking in oil right now.
spiderrey
Post by spiderrey »
its not a bolt. it is a stud permantly mounted.
Mark_vaughn
Thanks guys.
I will let you know how it turns out.
