fuel line connection gismo's
I'm sure this is an easy question for most but the 1st time I've run into it.My 82 fi spider has a leak in the fuel supply hose going to the fuel manifold. One end had a flared fitting the other has a barbed fitting and a collar. Does anyone know a trick in removal of the barbed end ? Will the reinstall be an issue without a clamp? Whats with the collar? all words of experience are helpful.
Re: fuel line connection gismo's
I don't think the barbed end is comming off without cutting the hose. I used an Exacto knife to cut the hose under the "hats". I think the "hat" might squeeze the hose a little bit to make it fit tighter. Make sure you use the proper high pressure F.I. hose, I bought mine from IAP, 7.5mm, but I think some have used 5/16, (8mm). I didn't want to take a chance with the barbed fittings, so I bought the correct stuff. You could use clamps if you wanted, but I don't think it's ever comming off of the barbed fittings. If you need to, you old lube the hose with fuel to make it easier to push on.
Trey
I cut the collars off, use a razor blade to cut the old hose. Make sure you use band-type clamps on the new hose rather than a screw-type clamp that cuts into the hose
Mark, are both of these clamps acceptable for fuel lines? The top one would be easier to install.
You mean fuel line, right? Top is fine, I guess the other would be OK if you had the proper tool to make sure it was attached correctly.
Trey
