I am planning on redoing the original drivers seat (the seat pan has big bowling ball size rust hole) but it is towards the bottom on the things to do list.
I decided to walk around the you-pull-it lot and see if there was something I could use for a drivers seat. I looked in the small cars and other convertibles to see if anything was the right size (hight, length width and rail bolts). Jokingly I looked into a early 80's Iszuzu trooper. I double checked the my messurements and the trooper seat is very close in size. I brought it back and istalled the spiders seat rails and it fits in the car. The back part is a little wider near the top but it is perfect for where I like the seat. Once i throw the seat cover back on the 2 seats look the same.
Replaced driver seat
Re: Replaced driver seat
Oh yeah? I'd need some proof. A picture would suffice.
No problem I will try an remeber to bring the camera to my storage unit / garage.
THis is what the original driver seat looked like
Here is the Iszuzu trooper seat installed
Trooper seat with old seat cover back on
Front view
Front view
The Izuzu seat looks nice in there. You should go get the passenger side?
Do you sit any taller?
I have thought about getting the passenger seat. The seat feels about the same height as the old seat did with a thin piece of plywood over the hole. Trooper seat might be a little higher is definatly wider front to back.
Looks like a nice fit. It also looks like it's going to be comfortable. With a little tweaking you should be able to twist the back so it would feel more original.
Thanks for the pics.
