Car starts fine. Runs OK at the beginning with temperature guage showing coolant temperature rising as normal.
Then, when the temp guage reaches, at what looks like, dead on 90C (194 F) and I change gear (foot off gas pedal) the engine cuts out. When it happens I can sometimes jump start if travelling fast enough or use ignition key to restart. No problem restarting the engine but will die if coolant at 90C and not in gear and foot off accelerator. If slightly below 90C after problem has happened, then car continues to drive fine until temperature rises to the critical level and it happens again.
I imagine its an electrical problem somewhere, but I dont understand what is happening or what to change.
Look forward to your guidance.
Engine dies at 90C when out of gear!
- Your car is a: 1985 Pininfarina Spider Europa
Re: Engine dies at 90C when out of gear!
It sounds like your engine is not idling properly. If you just warm up the engine in the garage or driveway or street without driving the car, does the engine die when the coolant temperature reaches 90 degrees? Regardless, I'd have the idle set properly when the engine is fully warmed up.
A remote possibility is that the Ignition Control Module (ICM) is failing when hot, which is pretty common. However, it usually doesn't fail as consistently as you describe, so I would start with the idle adjustment.
