Just wondering if anyone has seen this problem, which I've never experienced in 46 (forty-six!) years owning my '72 124 spider! I'm nearing completion of its restoration (almost 8 years now) and haven't actually started the car yet. I went to remove the ignition key two days ago and it wouldn't come out in the OFF position (or any other). It was a 'new' aftermarket model so I put the old, functional one back in yesterday. The key to the old went in and out easily before I installed it and immediately afterwards. Today, no luck, it's stuck too! The only thing I did in the interim was hookup the battery (temporarily) and test the operation of hazard, turn & brake lights. And they work. Related or not, I have pretty much disassembled and rebuilt the entire car including a new electrical system, fuel system, brakes and engine replacement.
Any thoughts on this would be much appreciated! Thx, Kaj
Key stuck in ignition switch
- Your car is a: 1972 Fiat 124 Spider
Re: Key stuck in ignition switch
Fixed (?) !!! I thought but had forgotten the key had to be rotated all the way counter clockwise, and maybe a bit forcefully. It then comes out of the original quite smoothly and the after market, a bit less so. I almost had the 2nd (original) removed, before discovering this. Don't feel so "wise" for be older!
Thanks for letting us know. The other thing that can happen is that the steering wheel lock is jamming a bit, making the key hard to rotate. To get around that issue, try jiggling the steering wheel a bit as you turn the key.
Thank you Bryan!
If someone sprayed a lubricant into the slot the key goes in, over time the lubricant can dry up and make the tumblers (pins) sticky. I have sprayed brake clean into the key slot then insert the key a couple times. wipe the key off with a paper towel and repeat until when the key is removed it is free of any contaminant. Sometimes rotating the key also helps free the pins.
