My Ansa muffler on my 81 Spider getting pretty rusty, I bought Ansa FA7245 from Auto zone , 4 bolt flange , looks like perfect fit , no welding needed, clamps at rear end into tailpipes
Question - my cat seems slightly rusty too, small hole at one seam , maybe original to car ?
- I see test pipe to replace CC with 4 bolts at each end, from Auto Ricambi , I’d love to put that in at same time.
My first time doing exhaust work, ready to have at it , This forum has been huge help time after time
There is no smog issue here in Florida, esp not for an 1981
Anything I need to be aware of or need to do ?
Thank you !!
Test pipe in place of cat converter
Online
Re: Test pipe in place of cat converter
It should be fine. Disconnecting the rear muffler from the center pipe can sometimes be difficult. The center piece is usually referred to as the resonator. I ran mine with a test pipe for several years, until I had to get an emission inspection.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Will it likely become much louder? , the Ansa it came with is nice , loud and very enjoyable sound, will be interesting to find out
Any advice on removing the rear of pipe ? It looks like it may be toughest part , also in what order would you remove , assuming I get test pipe
It’s resting on park brake cable now , burned the insulation on cable. , I don’t want to put strain on it
