Oil vapor separator question 1981 fuel injected spider.
sida555
Your car is a: 1981 Pininfarina
Post by sida555 »
Just wondering if anyone was able to take the Oil vapor separator out without taking the intake manifold out on a fuel injected spider? Can this be done or do you need to take the intake manifold out ?
ORFORD2004
Re: Oil vapor separator question 1981 fuel injected spider.
Post by ORFORD2004 »
I think so, just use a wrench key to remove the bolt
sida555
Post by sida555 »
Got everything apart cleaned up and installed back. No need to take anything out other than the bolt holding it down. You cant take the bolt all the way out, just take it out as an assembly.
