Hi all,
I've been trying to find a replacement for the larger front spring on the hood latch. No vendors have it and I can't find the right spring at my local hardware shop. Can anyone measure theirs and send the dimensions?
Thanks!
Hood Latch Spring
- Your car is a: 1979 Fiat 124 Spider 2000
Re: Hood Latch Spring
The spring has about 14 coils, the wire diameter is 1.50mm, and the length from the wire centers of each end hook is about 37mm, unstretched. Meaning the total unstretched length is about 38mm.
Hope that helps. You could give Chris Obert at FiatPlus.com a call, as he has a lot of stuff not listed on the website. He's probably got one of these springs rattling around someplace.
Thanks a lot, Bryan! I did check Fiatplus.com but didn't see the specific part. I'll give him a ring and see if he has anything. I'll also see if I can find something similar at another hardware store.
Joe
Apparently he's all out.
If you can measure the width and length of the spring as well, that'd be great!
Joe
I haven't checked, Did you post for a good used hood latch in the "Parts Wanted" section of this site?? The entire assembly might be easier to find that just the spring.
The width is 12mm, and the unstretched length tip to tip is 38mm. When the spring is attached to the latch, the spring is "sprung" just a little bit, so the length at that point is 42mm or thereabouts.79Temecula wrote:If you can measure the width and length of the spring as well, that'd be great!
Thanks, Bryan! Really detailed measurements. Hopefully I'll find something close to it.
Joe
Good idea about the whole latch. I think you're right--probably will have better luck finding a whole replacement!spider2081 wrote:I haven't checked, Did you post for a good used hood latch in the "Parts Wanted" section of this site?? The entire assembly might be easier to find that just the spring.
Joe
