Oil pump drive gear binding 2.0L
- Your car is a: 1982 Pininfarina Spider
The oil pump drive gear is binding against the aux pulley gears. I can see the drive gear moving up and down. How is it held in place? How do I remove to replace it? My manual doesn’t describe it.
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
Design Engineer
Zero Shock Seating
1982 Spider 2000
Re: Oil pump drive gear binding 2.0L
Why do you think it is binding? What is the problem?
The pump shaft has a spline and the gear drops into the spline. It is held down by the pump drive cap. W/O the cap in place, it is normal for the pump gear to lift a bit on the spline if turning the aux shaft the wrong way.
If you remove the gear with the engine in the car, be very careful; it can drop to the pan thru an opening in the block casting. Don't ask me how I know, but thank God for strong magnets.
When installing the gear, use a magnet or a guide rod to lower the gear into the spline to avoid losing it, unless on the stand.
The drive gear is held in place by one of two things: 1) A block mounted distributor (1968-1971 spiders with the 1438 engine), or 2) a "blanking plug" inserted into the opening, if your distributor is mounted instead on the exhaust cam housing (late 1971 and later as I recall).BammBamm wrote:I can see the drive gear moving up and down. How is it held in place?
The above is for the earlier models, so your '82 could be a different setup. My bad.
- Daddio
- Patron 2019
- Your car is a: 72 124 Coupe 2L project
I noticed a similar problem assembling a 2L recently; I adjusted the position of the oil pump (it has a little play around the bolts) to allow the gear to turn as freely as possible.
Jeff Aurand
Portland, OR
'72 124 Sport Coupe
'86 Bertone X "Anna"
'70 Volvo 145 "Edna", since 1989
'87 Maserati Biturbo Spyder 2800i
Portland, OR
'72 124 Sport Coupe
