Finally getting around to installing this kit...
https://autoricambi.us/headlight-relay-kit-1979-85/
What's the best spot to mount the relays? I have 2 unused (not sure what they were for?) bolts in the driver's side fender.
They are larger than the holes in the tabs on the relays. Should I drill larger holes in the tabs on the relays or mount directly into another spot on the fender? If anyone has installed this and has a picture that would be awesome!
Richard
1981 Headlight relay installation
- rjkoop
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- dinghyguy
- Your car is a: 1981 spider
Re: 1981 Headlight relay installation
i used the same bolts, and drilled out the mounting tabs slightly.
I also scrounged some old fiat connectors so i could make the wiring connections plug into the existing wiring connectors. That way I didnt have to cut anything and can put back to stock if i ever want to. A bit more wire required cause i had to run from the relays to the pass side headlight connector but i liked it better than cutting into the wiring harness.
One of the best mods you can make to the car.
dinghyguy
dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
- rjkoop
Thanks.
Actually I just finished the install... and saw this post too late.
Here's where I mounted it (beside/above those bolts)...
I used the self-tapping screw for the ground. Hopefully that will be ok. And I didn't have to cut any wiring. Just plug and play. Guess my kit is slightly different.
I'll test it in a few days. We're getting snow tomorrow in Ottawa. and I don't have the battery in the car yet.
Richard
Richard
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Although it is common to see sheet metal screws used to make the ground connection for an electric circuit a better practice is to use machine thread screw or bolt. I would use on of those 2 studs welded to the fender well for the ground. First clean off the paint around the bolt then put on a Star washer then the ring terminal then a flat washer then a lock washer and lastly the nut. Sheet metal screws can loosen in time reducing the quality of the ground connection.I used the self-tapping screw for the ground
- rjkoop
Makes a lot of sense. I'll test to make sure it's working and switch it over. Thanks for the detailed info on how to do it.
Richard
Richard
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
