82 Spider 2000 Brookline MA
- Your car is a: 1982 spider 2000
Purchased an 82 Spider 2000 that was originally a turbo (turbo removed) in August. Fun to drive, easy to push! Already replaced front bearings, oil pan gasket, alternator (reason needed to be pushed). Sorting out electrical issues.
- aj81spider
Re: 82 Spider 2000 Brookline MA
Welcome aboard. There are a few of us here in Massachusetts. In normal times we'd meet up at the Larz Anderson "Tutto Italiano."
Hopefully we'll run across each other soon.
A.J.
2006 Corvette
2006 Corvette
AJ, Larz is just down the street and I’ve been for many shows. If you have any recommendations on a good mechanic I’d appreciate it. I’m an engineer so I can usually figure out what’s wrong with the car, but fixing it is another story.
- Patron 2021
Welcome, There is some really good information on this forum. I have gone to DannyO'Donnel at Fun Imports in Vernon, CT for those things that are out of my range of ambition. If I find a mechanic in the area I will let you know. The last show I went to was Andover Cars and Coffee. I met a few owners there, Was an interesting time.
- aj81spider
Hi Weezerwill
In general I try to do things myself (it's a learning experience, although the car can be down for long periods). However I've used Danny O'Donnell at Fun Imported Automotive Toys in Vernon Connecticut when in over my head (like rebuilding a transmission).
Other than him I've only ever used a guy up in NH who did a worse job than I would have, so I wouldn't recommend.
A.J.
2006 Corvette
2006 Corvette
Yep, Danny.
- Your car is a: 69 AS Spider
Hi
and welcome! Will you rebuild your Turbo? Probably rare parts!
Can we get your car data for the worldwide Spider Register? We actually got 238 Turbo Spider of the approx. 700 cars built by Legend Industries.
Thanks and good luck!
Ciao, Ralf
Ciao, Ralf
69 AS Spider
the Worldwide Spider Register
