Transmission gear cluster removal
Mammothcaver
Your car is a: 72 spider
Post by Mammothcaver »
I have the transmission torn down and everything out. I need to remove the 1st and 2nd gear cluster from the shaft. Does this need to be removed all as one section? Any suggestions would be helpful.
ORFORD2004
Re: Transmission gear cluster removal
Post by ORFORD2004 »
If i remember correctly, you unbolts the gear cluster first
