Heater pipe
- Your car is a: 1981 Spider
Heater pipe
Had to replace the pipe from the heater core. On the hose side the new one does not have a rolled lip so as to hold the hose more effectively. Seems even when I tighten it pretty well it is still not as good a connection as one would wish. What do the rest of you do with these second rate pipes?
Re: Heater pipe
If the rubber hose is in good shape and the correct size for the heater core pipe, you should be fine. Use a good hose clamp and make sure it's tight of course.
On a few Fiats that I've had, the end of the pipe was essentially rusted away, and so I used a hack saw to take off about a half inch of rotten pipe (which of course removed the lip) and then readjusted the hose length to match. I don't recall ever having a problem.
Re: Heater pipe
Thanks a ton, Bryan.
Re: Heater pipe
You can also do as they do in the boatyard and double clamp the hose being sure to orient the second clamp 180 degrees from the first whenever possible.
