Leaky head gasket
vdesigner99
Your car is a: 1984 Pinanfarina spyder
Contact:
Leaky head gasket
Post by vdesigner99 »
All, just wanted to share some recent fiat experiences, I recently discovered that my 84 had a small coolant leak near piston 4 and below dizzy at the head gasket. Took car to shop since I didn't what to spend weeks working on it. Found out the the gasket had damage near the piston ring seal on the gasket. Also the head had a pit at that point also. Had to have a machine shop weld in aluminum and re-surface. I was told that because I was using standard Preston 50/50 and because I had aluminum head/ radiator there may have been galvanic reaction and caused the pitting to the head and other aluminum surfaces. He suggested using phosphate free coolant or reduced phosphate. I'm a prior member of the US Coast Guard so I know the cause and damage of galvanic corrosion can do. I decided to make and add a zinc anode somewhere in the coolant system in the near future.
Happy driving.
Victor
1971 MGB Roadster (sold)
1977 fiat 124 (sold)
2010 Prius
2001 Sequoia
2006 20' REgal bowrider boat.
1984 Pinanfarina
vdesigner99
Contact:
Re: Leaky head gasket
Sorry folks created in wrong forum, should be in engine forum. Not sure how to move it.
2010 Prius
2001 Sequoia
1984 Pinanfarina
spidernut
Post by spidernut »
That's a creative approach Victor. Ever consider this? Peak claims it is phosphate and silicate free. I'm glad you posted this. I've been using Prestone 50/50. Time to switch.
https://peakauto.com/products/antifreez ... ife-50-50/
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
DieselSpider
Post by DieselSpider »
There are several different formulations of Prestone 50/50 with a Universal, Toyota, Honda/Nissan, European, Conventional Green, etc, etc formula so you do have to choose the right one.
Critical too is a complete flush of the cooling system to remove any contaminants followed by a good rinse out with distilled water before adding the new coolant since you will not get the full 2 or 5 years of service from your coolant if you do not start with a clean system.
A 50/50 mix of distilled water and plain white vinegar is what I use for a flush now on all my cars, trucks and motorcycles.
I lean toward using the non-toxic formulations such as Engine Ice mostly because of their better cooling performance in the Deep South. I was a skeptic until the first 100+ degree day on a motor cycle and instead of the cooling fan starting and running the whole time I was at a stop light and not turning off until I had ridden a few blocks it turned on and cycled off in a few moments with no more upward swings of the temperature gauge.
