ignition problem
marcdh89
Your car is a: 1975 spider
ignition problem
Post by marcdh89 »
I have a 1975 spider that I an wrecking on. I have been stopped an ignition problem.
i am getting spark from the coil to the cap, bot not for the distributor to the the plugs
so far i have relapsed
the plugs
the leads
the cap
the rotor
the points
the condensers
and the coil
still nothing
if you advise please let me now :? :cry:
DieselSpider
Re: ignition problem
Post by DieselSpider »
Is the wire connected to the points in good condition? Many times they break internally from the movement of the vacuum advance, vibration and years of servicing.
zachmac
Post by zachmac »
What DieselSpider said. The problem has to be IN the distributor from your description. Power into but not out of the distributor = problem in the distributor.
BTW, I make typing errors all the time as well but got a bid smile from you saying you are "wrecking on" the Spider. I think I've done that once or twice when I intended to work on mine. :D
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
How did you test this. Did you crank the engine over with the starter and check for spark from the coil??
If so then I would assume the points are working and the distributor shaft is rotating.
I have held a spark plug on the cam cover and had no spark. THen I found the cam covers are not ground. Now I use the hood latch on the firewall to ground the spark plug.
GeorgeT
Your car is a: 1982 Fiat 124 Spider
Post by GeorgeT »
I believe that you have a dual point distributor, one set to start on and the other set after it's gets to temperature - make sure that both are working.
