adjusting head lights
grasshopper
Your car is a: 1976 Fiat Spider
Post by grasshopper »
Hi all. Can someone please explain how to take round chrome rings off of the car to adjust the headlamps ? I cant figure out how to take those rings off,,,
DRUMMOND
Re: adjusting head lights
Post by DRUMMOND »
There is a screw at the bottom of the chrome ring
Post by RRoller123 »
These screws are frequently stripped, mine are. Thankfully, the headlights are in position to pass inspection, so I haven't re-tapped to a larger size. But anyway, if they don't seem to adjust, this is likely the problem.
ORFORD2004
Post by ORFORD2004 »
[quoteThese screws are frequently stripped][/quote]
But they screw in plastic. Probably not to hard to remove.
Yes, probably easy to repair, I am just lazy since they point in the right direction. :wink:
baltobernie
Post by baltobernie »
Depending on model year, you may not need to remove the chrome bezel in order to adjust the headlamps. There are five identical #1 Phillips machine screws in each bucket. The three securing tabs hold the lamp in place. The other two adjust height and L/R. A shot of BP Blaster or Rost-Off on these screws and a sharp (properly-sized) screwdriver makes the job easier. YouTube videos and Internet posts abound with how to aim headlamps.
