booster adjustment
barnesjtsl
Your car is a: 1979 Spider
booster adjustment
Post by barnesjtsl »
What are the consequences of having the booster plunger adjusted in too far? Maybe 1/6 of an inch in ?
John
AndyVAS
Your car is a: 1980 Fiat 124 Spider
Re: booster adjustment
Post by AndyVAS »
The pedal must travel farther before engagement.
Andy Phillips
Vick Auto - Technician, Performance Engine Builder & PFI Developer (with ITBs)
http://www.vickauto.com
Odoyle
Your car is a: 1983 Pinafarina Spider
Post by Odoyle »
If the piston rod tip is extended past the specification, that would push the rear piston in the master cylinder inward farther than needed, potentially causing the brakes to lock up. You can try it, but you brakes might be glowing red after your first drive.
barnesjtsl
Thanks Odoyle,
I was driving at the piston rod receding into the booster a hair too far. About 1/16" short of the master cylinder.
Thanks again,
jb
