Proper Fuse - Fourth from left
whalford
Post by whalford »
Looking at the 1979 owners manual another user posted a while back, (see here:
http://users.telenet.be/Tappywappy/Pict ... manual.pdf), I am a little confused about one of the fuses. The fuse labeled "i" - what current is this supposed to support? The write-up beginning on page 43 indicates there are Nine 8-Amp fuses, and three 16-amp fuses in the fuse box, with another 8-amp fuse located separately.
However, on the next page, the fuse labeled "i"is listed as 25-Amps. They list either 8-amp fuses, and three 16-amp fuses. There's a big difference between an 8-Amp fuse and a 25.
mbouse
Re: Proper Fuse - Fourth from left
Post by mbouse »
"i" - (25 amp)
Quartz crystal clock
Courtesy light
Hazard warning flasher and indicator
Inspection lamp receptical
Remove key and fasten belts buzzer
'79-81
whalford
Post by whalford »
Yeah, I saw that on the next page, just wasn't sure if 25 was correct there, in light of the previous page. But I'll go with 25 and see what happens!
thanks,
-Bill
